RCU Forums - View Single Post - Cutting tail weight
Old 01-04-2012 | 03:13 AM
CGRetired's Avatar
CGRetired
Default RE: Cutting tail weight
If it's under powered, then replace the engine with that larger OS 50. That will certainly move that CG forward. Removing the screws is a possibility, but make sure you glue in the tail feathers so that they are nice and square with the fuselage and in alignment with the wing.
CGr.
