ORIGINAL: SeamusG
Nick - the pic of the mini servo is BEFORE the ''J'' hook hole was adjusted to be vertical rather than horizontal. With horizontal not enough room to easily loop the rubber band over the tip of the hook.
I used wing bolts so that wouldn't be a problem, but I have the throttle tube and servo alreadt mounted so im goin with the stock setup and cable. But i'm gonna use the micro on my next build. It is a good idea abnd will be one less servo I'll have to buy. Thanks!
