ORIGINAL: Baron Fel
To me I think that I'm over thinking this. I''m going to wire this as it's telling me. but can someone tell me why there are two micro switches?<div>
</div><div>Baron</div>
Hello Baron,
I have not worked with the SLU but if the SLU can run all the funtions of a Heng long tank set up as an Airsoft tank, then it can run the Asiatam unit. Just set the Asiatam unit up like you would if you are running Heng long, then set the SLU up as if you are installing it in a Heng long Airsoft tank and it should work fine. Please see attached link on how to set up the Asiatam recoil unit, and if the SLU has deatails on how to connect itself to the Heng long 8 pin turret connector not sure why it would not work? The two micro switch's on the Asiatam unit are to trigger the start and stop of the recoil & flash trigger.
http://www.rcuniverse.com/forum/m_10...m.htm#10033386
Phil
