RE: Glow Engine Mounting Screws
I also use sheet metal screws for mounting.
If the hole gets worn out from over use I enlarge it and use machine screws.
Anything you use has the potential to loosen due to the high vibration in our planes.
A regular ritual is to make sure everything is tight.
Good Luck,
KW_Counter
