RE: PX III Track Tensioners
Hi Jim, They look like copies of the Asiatam parts, which I have used, so they should work. The Asiatam's I used were easy to install. They had a template to drill the needed holes in the rear plate to mount them. The Mato set comes with the template as well. You will have to cut or grind off part of the original mounting points for the molded on track tensioners to mount these. Here are some photos of what the hull will look like once they are cut away and the hull is ready for the installation of the new metal tensioners.
