RE: elevator programing
Go into the model type menu. Select ACRO and then it will give you a menu for wing and tail type. For tail select AILEVATR. This activates the mix. Not sure what channels to plug the servos into so you will have to experiment. From there you will be able to figure it out. It is also on page 102 of you manual
