RCU Forums - View Single Post - SLU Help!
Thread: SLU Help!
Old 01-07-2012 | 09:05 AM
bubbajoexx's Avatar
bubbajoexx
Default RE: SLU Help!
ORIGINAL: Baron Fel
Bubba Joe, can you draw that out, I'm slow and Im not following you. Thanks!
go to the manual it shows where the micro switch plugs in the wiring for the switch is conect the micro switch nc contacs to the 2 wire plug and then plug it into socet C! on the SLU
next conect the recoil motor to the 2 wire plug and plug it into M! on the slu
next conect the elevation motor to the 2 wire plug and plug it into T$ on the esc and yoou will have a working unit
all the plug positions are marted on manual page 13
the manual has every thing you need
File Type: pdf
