Satio Question
I just built the You Can Do ARF plane and I put the Satio 100 engine on it. It appears that the fuel tank is too high and the carb is too low. This causes the fuel to constant flow causing it to flood. Other than turning the engine to lift the carb higher is there any other fixes that I can do?
