RCU Forums - View Single Post - Elevon setup in Futaba 10c
Old 01-07-2012 | 06:55 PM
TommyWatson
Default Elevon setup in Futaba 10c
I am helping a friend set up a Elevon equiped model. It is a E-flite Carbon-Z Scimitar. The radio is a Futaba 10C mode 1
It has two Elevons each with a seperate servo. I have set up the elevon function OK , BUT, The Aileron stick operates the Elevons as Elevators i.e both elevons operate in the same direction. The Elevator stick operates the elevons as Ailerons, i.e each elevon operates in oposite direction . it is as if the stick functions (ailerons and elevator) are reversed.
Is it possible to assign a function to a stick as I can do in my 14mz?. Any help would be appreciated.
I can see the servo movement on the screen.
Tom Watson
Sydney Australia
