RCU Forums - View Single Post - Going electric!
Thread
Going electric!
01-08-2012 | 03:31 PM
5
Per Strommen
Apr 2003
141
Son, NORWAY
RE: Going electric!
I feel confident this last change will do the job. The brass can be exchanged for steel if flying (poor landings) should bend the T-rod
The nose unit has worked flawlessly the whole time, but the nose wheel is 5 inch and the assembly is a lot lighter.
Pros and Cons:
Electric stronger, more consistent, weight saved on model, easy retract installation, no air leaks, no valves, no air lines, scale retraction speed
Not so good: A bit long retraction cycle (12 sec), more expensive
Reply
Like
Per Strommen
View Public Profile
Send a private message to Per Strommen
Find More Posts by Per Strommen
View iTrader Profile
