ORIGINAL: guver
ORIGINAL: jetmech05
I think there is one basic manuver you must master to start to get good and a trainer is perfect for it....if you can master this move with a trainer then you can do this move on any airplane at will....the manuver is inverted flight....don't just roll her over on her back and say there you go....no fly the whole pattern inverted.....Word of caution though.....when inverted and in doubt roll out.....always roll out of inverted flight...don't loop out....the ground will be alot closer than you think....I've seen a couple of good crashes from guys looping out of inverted flight....Good Luck....oh yea the ailerons..are the same inverted
I think this is going to be KEY for me. Someone rated it 5 stars , good job. I surely don't have it yet.
I think if I can do this and some nice 3-D I'll be well on my way.
Pretty much mastered it on the Sim with a T-34, Piper Cub and P-51. When Iget my T-34 converted to glow it will be my real test for inverted flying. Found a motor today for it at a swap meet. OS 52 4 stroke.
Also found a plane to put my DLE20 in. 6 foot span, should be a nice gentle flyer for breaking the motor in.
www.rcuniverse.com/forum/m_10898465/anchors_10898478/mpage_1/key_/anchor/tm.htm#10898478
