RE: Round rudder servo arm
Todd has an elevator setup where the duel servos are at the center section of the fuse and two thin CF rods are making the direct connection.
Seems one can do the same for rudder? That is, no pull-pull but a long CF rod passing through several balsa "bushing" plates.
Not to argue that pull-pull is not ideal for pattern but like to bounce a potential different setup idea.
