RCU Forums - View Single Post - Slow vs Fast flying Planes
Old 01-09-2012 | 09:01 AM
cfircav8r's Avatar
cfircav8r
Default RE: Slow vs Fast flying Planes
The spitfire gains speed fairly quickly when the nose is dropped. If you have it set up so that the prop stops when the throttle is off, you might try setting it up to allow the prop to freewheel when you close the throttle. This increases drag allowing a steeper descent without gaining excessive airspeed.
