RCU Forums - View Single Post - Remote engine kill - Switch or Choke
Old 01-14-2012 | 09:20 AM
BadAzzMaxx
Default RE: Remote engine kill - Switch or Choke
The advantage is if you lose signal to the receiver or lose voltage to the receiver it will kill the engine.
But if you have fail safe set up right it will do the same thing unless you lose voltage.
Also if the transmitter is turned off you will not have voltage to the ignition even if the switch is turned on.
Milton
