OK now, I spent some more time cleaning up the lower hull. Some green modelers putty and some sanding....then I went over the plates with dremmel and a grinding head set on slow speed to try to get some texture like rolled armor plate has....</p>
</p>
then some suspension....</p>
</p>
then painting the kt wheels....I m using rustolem primer red...</p>
</p>
and then the wheel.....</p>
</p>
</p>
If you nitice, I openedthe spacing on the middle wheels a little for looks...I kinda figured that then middle of the tank might need a lrger boggie tohand the extra weight of the 88....
with a little luck, I cangetsome work done on the upper hull this weekend.....while i wait for some stufffrom phill....</p>
