ORIGINAL: MinnFlyer
ORIGINAL: Zor
I wish to read the advantages of using CA hinges over pinned hinges.
Ok, They are easier.
<span style="color: #ff0000">I think you mean easier to install.
For me the pinned hinges are easier to install because I have the Dubro tool to cut accurate slots. </span>
You don't have to cut the same slot, you have a much easier slot to cut because they are not so thick.
<span style="color: #ff0000">The Dubro tool cuts the slot just the proper size for the thickness of the hinges.
The 0.610 inch wide hinges are 0.032 to 0.035 thick.
The 0.428 inch wide are 0.025 thick.
For a $10.00 tool, who would want to cut 44 slots with a #11 Xacto knife on a biplane.
24 slots for 4 ailerons.
8 slots for rudder
12 slots for elevators.
Of course the tool is there for future models.</span>
Also the gap is small enough to be negligable, yet for flat, nylon hinges you have to cut room in the TE of the Stab and LE of the Elevator to make room for the knuckle - otherwise you get a HUGE gap.
<span style="color: #ff0000">The CA hinges that I have are 0.017-0.018 inch thick.
</span><span style="color: #ff0000">I would not want that thickness to force apart the grain of the wood.
How to cut 44 slotsto bejust about that thick? I do not know of any tools to do that.</span>
<span style="color: #ff0000">If you did mean "easier to install" then it appears labor intensive and time consuming.
A slot using the Dubro tool can be cut in about one minute or less.
</span>
Next is the fact that you need to use epoxy or some other slow-setting glue which must be applied, hinge inserted, glue applied to the other side, control surface added and then all that messy excess glue has to be removed.
<span style="color: #ff0000">That is not the way I do it. I have previously described in this forum how I do it. I will not repeat here now what I already posted. The epoxy is applied only once on both faces of the slots and the hinges and I have no mess and no epoxy coming out to the hinges themselves. There is always a solution to any problem like you are mentioning. </span>
So basically, once you have test-fit pinned hinges, you have several more messy and laborious steps.
<span style="color: #ff0000">I wonder what messy and laborious steps you are experiencing. After final insertion of the pinned hinges, there is no mess to clean up. Just let the epoxy harden up in less than an hour using 30 min epoxy. </span>
With CA hinges, after the test-fit, add a few drops of CA and continue on to the next step. No waiting necessary.
<span style="color: #ff0000">Ya ___the next step is to relax with a nice cup of coffee or your favorite beverage _
_
. </span>
