RCU Forums - View Single Post - Blade SR120 Spinning Problem
Old 01-22-2012 | 08:00 AM
airshot
Default RE: Blade SR120 Spinning Problem
Sounds like the tail motor is not able to keep up, probably going bad or faulty. By adjusting the rudder trim you cannot stop the spinning? I that is the case you call to HH is necessary. Good luck...Good Flyin..
Airshot
