RCU Forums - View Single Post - DIY german E50 build
Old 01-24-2012 | 05:25 AM
  #31
mustclime's Avatar
mustclime
Default RE: DIY german E50 build
Yup, If you look at the upper hull and the front of the turret...they are both 60 degrees, one our way, one their way...I still have some work one the suspension, the last wheel on the right side hits the idler. I am going to have to cut it out and move it forward about 2mm....funny since I did not move ether the ft or rear suspension mounting points on ether side. Just the act of makeing the rear wheel a inner wheel made it hit the idler. It did not do this on the left side because the swing arm moves foward rather than rearward.....
