RE: Engine mounting
There should be a mark on the firewall a cross....or the plans will have a cross...this is the thrust line and off set.....the intersection of the cross should be dead center on the back of the engine.....or you can do some measuring like you're mounting the engine straight and just turn everything 45 deg
