RCU Forums - View Single Post - UCanDo, snaps like a Cap at low speed??
Old 08-27-2003 | 02:36 AM
Heads_Up
Default Re: UCanDo, snaps like a Cap at low speed??
Originally posted by fxstbi
I just put the first flight on my UCD tonight and it tip stalls badly! I'm using a Saito .100 and the c.g. is right on the money. I am using the rates they describe in the manual and I'm having tip stall at any setting above the lowest rate. I keep reading about how everyone is moving the c.g. back to 6", I would think this would exasperate the problem! Any thoughts? Thanks, Pete
Couple of things it could be...
Have you checked the lateral balance?
Have you checked the elevator halves? Are they traveling at the same rate and distance?
What thrust line are you using on your Saito? How much right thrust and up thrust?
Just a few ideas off the top of my head.
Rick
