RCU Forums - View Single Post - UCanDo, snaps like a Cap at low speed??
Old 08-28-2003 | 01:36 AM
Heads_Up
Default UCanDo, snaps like a Cap at low speed??
One more thing I thought of...
If you are using the stock push rods that came with the ARF, the longer one is probably flexing more in flight than the shorter one. That would cause the elevator halves to move at different speeds. Try using 4/40 steel rods instead of the 2/56 weak aluminum ones that come with the plane.
Just another thought.
Rick
