RCU Forums - View Single Post - 450 Clone setup, HELP!
Old 01-30-2012 | 05:54 PM
gi1mo2
Default RE: 450 Clone setup, HELP!
Look at the Swash Mix. The 3 values are around +60% on mine. In some cases, you might have to use an equivalent negative number to get the right movement. You may need 2 values positive and another one negative. Trial and error there... To get more movement, increase or decrease number if negative... Check your servo reverse switches as well. Both in combination will have weird results.
