RCU Forums - View Single Post - Prop on a car engine
Old 02-01-2012 | 11:34 AM
  #39
rgburrill's Avatar
rgburrill
Default RE: Prop on a car engine
ORIGINAL: 1QwkSport2.5r
ORIGINAL: rgburrill
I don't get it. Changing carbs, adding flywheels, changing heads? How does this provide any comparison between engines? Why not just get an older car/truck/buggy, put your test engines in it and run the heck out of them?
I personally would want to simply break the engine in, only because I don't think a car engine gets to its peak during break in and it should, IMO.
I can see the reasoning behind what the OP wants to accomplish. It's no different than testing a certain prop on more than one engine to suit a specific aircraft.
But testing a prop on various engines doesn't mean tearing the engines apart and changing heads and carbs. Break-in simply means running at less than full-out to start. It used to be that you would break-in a full size car with break-in oil and keeping under certain speeds for 500 miles or so.
