I hooked upthe servos and installed the receiver today. I could not get the aileron programming to work right when I kept the flaps on the flaps channel. So...I went out and bought another y-harness and I'll do it the old fashioned way. The motor won't run because the carb is all gunked up.The new carb I got has a choke so I think I'll use the extra channel to operate it.
I noticed that when operating the flaps, one seems to lag a little behind the other. It over travels a littleand kinda wags back and forth until it finds the correct position. This only happened when operating the controls quickly. The flaps are already hooked up with a y-harness. I don't know what kind of servo is used because they were already installed in the wing and I didn't want to take them out and have to worry about fishing the servo wire back through the wing. Any ideas of what is causing this?
