RE: Prop on a car engine
I can promise you that unless you use a very small prop, getting over 28,000 rpm will be almost impossible with a prop. I am more interested in this as I think it would be awesome to convert a small car engine to fly a plane. Using a prop to break in your engines does have a lot of merit though and it seems you could get the needles set very easily if you could match the load experienced in your car.
