RCU Forums - View Single Post - advice needed
Old 02-01-2012 | 09:08 PM
travis3.5
Default advice needed
Back story: i was dirving my earthquake 3.5 miss judged the distance and ran into a pole. The parts I replaced are gas tank, all drivelines, front dif, transmission, and steel spurr. Before i replaced all this the car was unable to roll backwards and after replacing all this it now can. Is this normal? thats just a side problem the real problem is with it running. It idles and runs just fine smoking a lot like i want it to ( lots of open fields so lots of wot). Now as soon as you get wot it instantly dies. No bogging or anything just out right dies, leaned it out and then ist a no start. Checked the idle on the inside of the air filter and its 1mm open (as should be?). runs with lots of power and torque until wot. To the best i could i did research and checked piston sleve wear. glow plug out as piston makes its stoke ever so often resistance and a slight pop sound (like a wine bottle top but not as loud) so compression ok as far as i know from research. Is this another broken part that i missed or is this tuning issue.
