RE: Epoxy CA hinges in place?
Thanks for all replied.
The plane will be e-powered so vibration is very minimal.
Whether epoxy can effectively bind the ca hinge material to wood is a valid concern. Some experiment probably should be conducted.
Since epoxy can be applied in such a way to avoid the to narrow center section, the hinge should be quite flexible and not brittle at all.
