RCU Forums - View Single Post - Epoxy CA hinges in place?
Old 02-04-2012 | 05:47 AM
EHFAI
Default RE: Epoxy CA hinges in place?
It's important to recognize that all CA hinges are not equal. An easy test is to grasp a hinge with two pliers butted together at the "hinge line" and try to separate / tear the hinge apart. Many tear as easy as paper, others can't be torn. I find Radio South Pro hinges always pass this test and hold up for thousands of flights in both glow & E powered pattern airplanes.
