RCU Forums - View Single Post - multiple motor setup and wiring
Old 02-05-2012 | 05:29 AM
phmaximus's Avatar
phmaximus
Default RE: multiple motor setup and wiring
ORIGINAL: stealthapotomus
Hey guys I was wondering If it was possible to wire 3 Motor esc combos into three different channels so that they could be controled separatly on my transmitter.<div>
</div>
Yes u can, say if u were using the traxxas 4ch/5ch with switch mod controller u could use..
ch1 steering
ch2 throttle
ch3 selects 1st ESC & motor
ch4 selects 2nd ESC & motor
ch5 selects 3rd ESC & motor
this way u can run all of them at once, 2 at once, or just 1
ch1 steering
ch2 throttle
ch3 selects either 1st ESC & motor or 2nd ESC & motor
ch4 selects 3rd esc & motor
ch5 spare
This way u could run only 2 at once but not 1st & 2nd at the same time, only 1st & 3rd or 2nd & 3rd.
All u would do is use a electronic switch to interupt the throttle signal wire from the reciver.
There are heaps of variations of this to, there are simple on/off switches or there are switching switches that have 2 inputs/outputs.
