RCU Forums - View Single Post - Using Throttle Delay for other function
Old 02-06-2012 | 11:55 AM
Bax
Default RE: Using Throttle Delay for other function
Use any unused channel as the slave to the mix. You can use channel #7, even when it has the battery in it, by using a "Y" harness....or just plug the battery into a different, unused channel. Works fine.
