Using Throttle Delay for other function
My Feedback: (10)
I have a 10C radio with a R617FS RX, I am interested in using a retract Servo (Spectrum A7000 Retract Servo) that can be slowed down and want to assign it to the Throttle Channel so I can use the Throttle Delay or Slow Servo function; I have read the instructions on the Futaba Web site how to do this, the instructions indicate that you assign Throttle Function to another Channel namely Aux Channel #8; however, the R617FS RX does not have 8 Channels only 7 and I am using all 7 with the Battery plugged into 7, can I just swap the Throttle(#3) and Gear channel (#5) around to accomplish this, substitute Channel #5 for #8 in the Instructions given?
Thanks, Doug.
Thanks, Doug.
My Feedback: (10)
Bax,
Appreciate the reply, I was trying to swap Channel #3(Throttle) with Channel #5(Gear) so I could use the Servo Slow Function and I found out that it can't be done like that; you have to use an unused Channel, like you said, and since I was using all the Channels I used a 'Y' on #7 with the battery and it works fine like you suggested; However, how do you get the Throttle Kill function to work on Channel #7?
Again, thanks for your help. Doug.
My Feedback: (10)
Another quick question with this set up; to recall, I'm using the 7 Channel R617FS Receiver and all Channels are used; I have placed Throttle(Channel#3) onto Channel#7; and put my Retracts(Channel#5) on to Channel#3; with this done now leaves Channel#5 open, can I plug the Battery into this channel, I am trying to avoid using a 'Y' on Channel#7 for both Throttle and Battery.
Thanks, Doug.
Thanks, Doug.
You sure can, you can plug the battery into any open channel on the receiver that you like.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
