RE: Using Throttle Delay for other function
Bax,
Appreciate the reply, I was trying to swap Channel #3(Throttle) with Channel #5(Gear) so I could use the Servo Slow Function and I found out that it can't be done like that; you have to use an unused Channel, like you said, and since I was using all the Channels I used a 'Y' on #7 with the battery and it works fine like you suggested; However, how do you get the Throttle Kill function to work on Channel #7?
Again, thanks for your help. Doug.
