RCU Forums - View Single Post - A 4 SKYHAWK AIRFOIL
Old 02-08-2012 | 12:08 PM
pimmnz
Default RE: A 4 SKYHAWK AIRFOIL
If you want it to do tight turns, the airfoil really does not matter, the weight does. With model airfoils all performing much the same, regardless of section shape cause the all stall around the same AOA, the determining factor in accelerated flight, ie turning, is wing loading. Make it lighter, and it will turn better.
Evan, WB #12.
