ORIGINAL: BaldEagel
ORIGINAL: David Gladwin
Hi Jason /Carsten.
What's wrong with poo pooing myths if you have real data with which to work and that data contradicts the myth !!!
Regards,
David.
I did write a long reply, but decided in the end that your are just too intranciant for words. It must be wonderful on your planet where the only person that can be right is you.
Mike
I have to concur with David G's findings. I run Weatronics as well and my CARF Hawk never pulls more than 3 amps overall with 7x JR 8711's and even then only for a split second. Most of the flight averages 1.5 amp draw. You just don't see the big amp draws in jets like you do in 3d planes.
Not trying to detract from the Futaba thread, I'd luv to have an 18mz but, it'll never happen because it doesn't have a module and I can't plug my Weatronics gear into it
Mike
