Here's the fin partly built, and about to frame up the rudder.
I built the rudder as designed, except I extended the area of solid wood up a bit. That way I can mount the control horn higher, if I need to.
Mocking up the tail, the vertical stab and rudder seem small in comparison to the rest of the plane.
I can always build a larger rudder later, I suppose, if I felt the need.
