RE: Cowl material 3d hobby 540 edge
It's most likely Polyester. Warm it up slightly with a heat gun, if it gives off an odor, it is poly. If not then it's epoxy. Either way you can do what you need to do using epoxy, just rough up with 100 grit and clean with alcohol.
