RCU Forums - View Single Post - Painters ?????
Old 02-19-2012 | 08:21 AM
SunDevilPilot's Avatar
SunDevilPilot
Default RE: Painters ?????
I use a coat hangar inserted into the hinge holes. The hangar is bent in a way I need to pull it wider to get it to enter the holes. With some tension built into the wire the surface will stay on the wire while painting. The wire makes for a nice handle to hold while painting. It is then used to hang the part while it dries. When done you just pull it out.
SunDevilPilot
