RCU Forums - View Single Post - Exponential on Elevator?? Is it required on a Bandit.
Old 02-19-2012 | 07:33 PM
roger.alli's Avatar
roger.alli
Default Exponential on Elevator?? Is it required on a Bandit.
How much, if any elevator exponential do you use??
I have been having a little trouble landing my new Super Bandit.. I am not really in control of it pitch wise, in the final hold off, right before touch down. Instead of getting a nice flair and nose high touch down, I am tending to do a little balloon climb to 5’ or so, which results in a nasty flop onto the run way.. (Fortunately the SB is built tough.)
My theory is I am over controlling, possibly due to elevator exponential.
Typically Bandits need a lot of elevator throw to hold off in the final stages of landing. (If you touch down early/fast, the dreaded Bandit bounce happens). To compensate for this high travel rate, I have been running 35% exponential, in an attempt to de-sensitise it at normal flight speeds.
However, I fellow modeller suggests this might be getting me into to trouble. Right before touch down, while holding in a lot of back stick, the exponential is actually making it more sensitive to pitch, which when I think about it would seem to be the case..
Any ones thoughts would be appreciated..
Roger
