RCU Forums - View Single Post - Exponential on Elevator?? Is it required on a Bandit.
Old 02-20-2012 | 02:39 AM
Countryboy's Avatar
Countryboy
My Feedback: (25)
Default RE: Exponential on Elevator?? Is it required on a Bandit.
ORIGINAL: roger.alli
How much, if any elevator exponential do you use??
I have been having a little trouble landing my new Super Bandit.. I am not really in control of it pitch wise, in the final hold off, right before touch down. Instead of getting a nice flair and nose high touch down, I am tending to do a little balloon climb to 5’ or so, which results in a nasty flop onto the run way.. (Fortunately the SB is built tough.)
My theory is I am over controlling, possibly due to elevator exponential.
Typically Bandits need a lot of elevator throw to hold off in the final stages of landing. (If you touch down early/fast, the dreaded Bandit bounce happens). To compensate for this high travel rate, I have been running 35% exponential, in an attempt to de-sensitise it at normal flight speeds.
However, I fellow modeller suggests this might be getting me into to trouble. Right before touch down, while holding in a lot of back stick, the exponential is actually making it more sensitive to pitch, which when I think about it would seem to be the case..
Any ones thoughts would be appreciated..
I would say your theory is probably correct. When I set up my F-4 elevators, I put in 30% expo and found that the expo was causing an overly senstive elevator on the flair. Dropping the expo to 10% helped and I am thinking of even taking that out and using the servo slow function to slow the servos a bit. If you watch the video here with Lewis Patton at the sticks, you can see on the landing that the elevator is a bit senstive due to the expo.
http://www.youtube.com/watch?v=EInnRANOm7s
Roger
