ORIGINAL: ameyam
Hi,
strictly speaking, this is a radio setup question. But I couldnt find a radio support forum so I am posting it here. I have a 9CAP with 2.4GHZ module setup with a DLE20. Now my problem is that, at landing, even if I add one click of power, the airplane just zooms off back up i.e. its producing too much power at too low a stick position. This is a classic case for a throttle curve. However, I couldnt find the setting anywhere on this TX. When I read through the manual (actually, I searched for throttle curve in it), the only references are in the HELI mode. Doesnt the 9CAP have throttle curve in ACRO mode? If not, it plain @&$%#%.
Does some one here have an answer to my problem?
Ameyam
Just use mechanical differential on the throttle / servo linkage. A good description of this has been presented on this forum and was authored by Jedijody. Very easy to do and every bit as effective as an electronic curve. I've been doing this for years to prevent what I call "toggle switch" throttles.
