RCU Forums - View Single Post - Exponential on Elevator?? Is it required on a Bandit.
Old 02-20-2012 | 02:29 PM
roger.alli's Avatar
roger.alli
Default RE: Exponential on Elevator?? Is it required on a Bandit.
Dave W,
I ALWAYS land with the full flap setting. BVM use a jig to set up. I think it is 45 deg.
This is the Comp Super Bandit which is STRONG, but heavy. It weighs 24 lbs bone dry, and carries 3.5 litres of fuel..
I also own a classic Balsa Bandit which I do recall needed the CG way further aft then the plans indicated. That model is only 19lbs dry)..
It is all pointing to moving CG back, and reducing expo..
Roger
