ORIGINAL: ameyam
Hi,
strictly speaking, this is a radio setup question. But I couldnt find a radio support forum so I am posting it here. I have a 9CAP with 2.4GHZ module setup with a DLE20. Now my problem is that, at landing, even if I add one click of power, the airplane just zooms off back up i.e. its producing too much power at too low a stick position. This is a classic case for a throttle curve. However, I couldnt find the setting anywhere on this TX. When I read through the manual (actually, I searched for throttle curve in it), the only references are in the HELI mode. Doesnt the 9CAP have throttle curve in ACRO mode? If not, it plain @&$%#%.
Does some one here have an answer to my problem?
Ameyam
Hi,
Problem is not with TX. The problem is the timing curve on the DL 20 Ign. It jumps to full retard and full advance all at once.If you Ign has a No#4 on the case,it has the screwey timing.You need a RCEXL Ign for a DL30 ot 55.
You about have to put a timing light on the Ign to see this.RCEXL nos this is not right but this is what DL wanted. Not RCEXL fault. I am flying two DL 20s.But I build my own ignitons.You can use expo on the throttle will help some but will never ovrcome the timing problem.
BCCHI
