RCU Forums - View Single Post - Throttle curve on 9CAP
Old 02-21-2012 | 10:52 AM
Javier-RCU's Avatar
Javier-RCU
Default RE: Throttle curve on 9CAP
The solution to your problem is really easy. First of all you have an excellent TX. The 9CAP have two mixes with curve, i think they are mix number 6 and 7. You can set the throttle as a master and one aux channel (7,8) as a slave, you can connect your throttle servo to the slave channel and program that curve. This trick works perfect to me.
Javier
