RCU Forums - View Single Post - Throttle curve on 9CAP
Old 02-21-2012 | 11:43 AM
Javier-RCU's Avatar
Javier-RCU
Default RE: Throttle curve on 9CAP
ORIGINAL: ameyam
Thats super, Javier. I will try that on the model this weekend. Should I rely on the onboard tach to set the curve? i.e. I can get readings from idle through WOT and then plot that on a graph. Then mirror the curve about the linear to get a negative curve that I need to set for throttle and then set the corresponding points on the slave by changing the pecentage while the engine is running
Ameyam
Yes!
