RE: Question on Vector Thrust
Tony
Around 30 degrees would be a guess, you are limited by the tube diameter 3 1/2" is a good starting point. Turbine Tail pipe diameter will stop the deflection.
I had a Zimmermann set up in my Rookie and Harpoon 11 and it worked well.
Dw
