Here you go
http://www.thompson-aero.com/index.p...d=62&Itemid=32 also how are you balancing your props? Simply balancing your prop in the horizontal position is not enough and wont show you if you have a hub thats heavy on one side. You need a good balancer
http://hobby.dubro.com/videos/1/tech-tip-videos Check out these videos. Good luck
