RCU Forums - View Single Post - Need help with prop tracking...
Old 02-24-2012 | 10:47 AM
rgburrill's Avatar
rgburrill
Default RE: Need help with prop tracking...
ORIGINAL: jetblast96
ORIGINAL: Hobbsy
...notorious for having the hole drilled crooked through them.
Should I not use APC on my airplanes then? The only reason I'm checking prop tracking is to get a smoother running plane without all the massive vibrations that I've been experiencing. I have no doubt that my drive washers and crankshafts are straight; these engines have not been crashed and the Saito has only been run twice on the bench; otherwise factory new. Should I switch to a different propeller and try again?
Thanks for the replies
Mike
<br type="_moz" />
Didn't you say you have prop strikes nearly every time? That'll damage your bearing and even your crankshaft more than a crash in the dirt.
