ORIGINAL: Prop_Washer2
I fly an Aurora 9, but if you are on a really tight budget, here you go. Use your old switch, maybe some fresh batteries, and your old servos should work. These radios are used around the world and appear to function quite well, probably less than $80.00 delivered from their USA warehouse...
http://www.hobbyking.com/hobbyking/s...arehouse_.html
How do you find the Aurora 9 2.4 is for programming compared to other units?
I want to step up from my JR XP 7202 & Hitec Eclipse 7 to get into the 2.4 technology.
I will still keep and use the old 72's but have acumilated several toys that fly in the 2.4 range.
I also want to be able to replace the toy type of tx units that came with my 2.4 toys and use a full function tx like the Aurora 9 or the Eclipse 7 Pro etc.
Your thoughts?
