RCU Forums - View Single Post - How to cut wing ribs
Old 02-26-2012 | 11:22 AM
yel914's Avatar
yel914
Default RE: How to cut wing ribs
You're right, a balsa template is a bad idea. I just used this as an illustration of the procedure. I usually use a product called Chemetal for templates. It's thin brass bonded to laminate(formica). The stuff lasts forever and I have a bunch in my stash. The main advantage over using a router bit is there is no tearout when climbing the grain. Much more consistant results.
