RE: Plettenberg maintenance?
Thanks for the pictures.
Wonder if you can make a "sizable" hardwood dowel that matches the OD and the shape of the ring perfectly from the back side, and use it to gently hammer the ring out. The bearing has to be sit on a wood block with the round cutout in the middle to allow the ring to pass through.
You may freeze the assembly. Maybe it helps the process.
